Likes Likes:  1
Results 1 to 5 of 5
Thread: Stallion water pump 2013
    May 2019
    Miami FL USA
    Default Stallion water pump 2013
    Good day everyone, Does anyone know part number of how to get a new one?
    Sep 2022
    Signal Mtn TN
    The engine is from a 2007 Ford Ranger 2.3 engine. Shop for the part using those perimeters. Should come up easy.
    May 2019
    Miami FL USA
    Default Thank you for your reply
    Apparently it's got some fabricated adapter my mechanic said.
    We have bought all the Ford parts.
    Any thoughts out there?
    can't the adapter be moved to the new pump? otherwise call Motor trike in troop Texas, ask them they built the stallion.
    May 2019
    Miami FL USA
    Default Thank you will do.
    Thank you.
  1. Water pump took a dump (maybe)
    By Zammy in forum Harley Tri Glide
    Last Post: 01-11-2019, 05:57 PM
  2. Water pump failues
    By Old Bear in forum Harley Tri Glide
    Last Post: 09-04-2018, 08:09 PM
  3. Water Pump.....again
    By DamnYankee in forum Harley Tri Glide
    Last Post: 06-24-2018, 05:12 PM
  4. water (oil) pump cover
    By jmhenrie in forum Harley Tri Glide
    Last Post: 10-04-2017, 07:37 AM
  5. Water pump noise
    By GoldWingrGreg in forum Honda Trikes
    Last Post: 06-18-2017, 06:48 AM
