Had a Michellin MPA put on my GL1800 Hannigan this morning.Mounted in reverse. <br />
Y'all were right - ride and handling (and steering) immediately improved over the Metzler that was there when I bought the trike.<br />
OK now the problem- there is a quite strong buzzzzz(vibration) between 25 and 35 miles per hour. I can feel it in the handlebars and it is the same when accelerating or decelerating and with clutch in or out. If I gently depress the front brake I can feel it in the brake lever too.<br />
Has anybody had this problem and if so, what did you do about it?<br />
I've only put 100 miles or so on the tire - maybe the buzzzz will just go away? <br />
Thanks in advance for your thoughts.
