I was caring my garage door opener in my right hand fairing pocket and when I got home would stop and open it but found that it was always on the bottom of other stuff we keep in there. So each time I tried to use it I would end up knocking something out on the ground.
Well I had an old opener that the clips were broke on and the case would not stay together. I took this and found the the button on the circuit board and solder two wires to the circuit board. I open the left fairing pocket and found that a small hole was already in the pocket that I could run the wires through.
Next I drilled a hole beneath the pocket where naviagation would go and placed a momentery switch there wired to remote. I might add a voltage regulator later and make it so i can just used the circuit card with out the disposible batteries.
No more need to open pocket now.
