120R plugs?
Oct 15, 2011
291
10
NE OHIO
Hey, you guy's with 120R, or 124s&s, or 120HQ, what spark plugs you runnin?
I'm chasin a "ping" and I think I want to go colder? HD don't have a colder one.
Need thoughts and part numbers please.
eighty80.
Harley does have a colder plug its a 10R12. Also you can use NGK DCPR7E (I think I have the right number) as well as a colder plug.
You also should check your plug gap. No more than .40 gap. A better gap is .35-.38 if the gap is too wide its possible to get have a weaker spark for the compression.
You should also do a data run to record when your hearing the spark ping to pull some timing out in that rpm/throttle area
Tom
Thank-you!! That's the info I was looking for.
I wish I knew HOW to pull the timing out??
I have never did a data run or even hooked up to a computer.
Thank's again. George.
+1 what FLTR says, I'm running the NGK DCPR8E set at .035. I'm finishing up with night shift tonight and will be out in the back garage sometime around 10:30 Monday morning. I'll shoot you a PM with my home phone and cell phone, I can help you out with the timing.
ThumbUppepperThumbUppepperThumbUp
Roadrunner1
Roadrunner1
