Hi. With about 6000 miles on my Stallion, my cruise control simply quit. Fuse fine. Brake lights not on. No indicator on instrument panel.
Any troubleshooting tips please?
Mike
Mine quit a few years ago. Under the bike on the brake linkage, there is a tab which contacts a switch. A slight bend of the tab corrected the problem.
Thank you so much for the tip. I am still over a thousand miles from home. I assume the brake linkage is a rod which runs to the back of the bike. Is the switch blue and white?
I guess I will purchase a couple of ramps to get the bike up and go under it (when I get home) as if doesn't sound like something I can try to fix now. Oh only to have a pix diagram labeling all of the components!!!!
on another thought I am thinking about having a machine shop create a belly pan with quick release fasteners to completely enclose the bottom to keep road debris off.
Thanks for responding
mike
ps. How do I post photos?
mike
Thank you so much!!! This is of awesome help !!!!
Mike, here a pic of the cruise control unit. That was the first thing I checked, but unfortunately the unit had to be replaced. Good Luck.
ive had the same problem with my 2010 model.....and it turned out to be a bad secondary brake switch....Hi. With about 6000 miles on my Stallion, my cruise control simply quit. Fuse fine. Brake lights not on. No indicator on instrument panel.
Mike
mike
I bent the tab and now it works! However, when I hit a bump it cuts off. Did I bend it too much or should I back it off a bit please?
