Help - my bike won't start
Dec 17, 2011
37
8
Ash, NC
1999 GW 1500SE Lehman
Had been away for a few weeks and forgot to put tender on bike. Tried to start and got nothing - no click - no electric. Put on tender for 24 hrs and showed full charge. Tried to start again - no click - no electric, but when I turned off heard a buzzing sound, even when I put in locked position! Put on tender and showed too low voltage (red light blinking continuously). I waited a day and put on tender for 24 hrs again and went to start and same thing happened - no click - no electric and buzzing sound when I turned off (again even in locked position). I thought it sounded like something electrical (battery discharging???) I'll have to have it towed to shop, and I wanted to see if anyone might have an idea of what it might be before I have it towed. Battery, starter, electrical??? I appreciate any and all input because, as I said, I am a dummy when it come to the mechanics of my bike. Thank you for all your advice.
:(:confused::xzqxz:
Don't know for sure but I would try to take the battery cables off, clean them vigorously and then re-install. Try that first anyway. If that fails then you're back to plan B.
Check you battery ground.....remove from frame, clean and add a little cup grease between cable and frame.
8~\o
:(:confused::xzqxz:
Have the battery tested. Most auto parts places will do that for free.
How old is your battery?
it seems like battery's are tender little things?
If you keep it on a tender you may not notice at first it is getting weak, Has it given any indication that it really doesn't want to start before under some conditions?:Shrug: any hesitations?
Sounds like the battery went out on you.
When a battery starts to get old or used then it is drained it can go south because of the stress. The red blinking light is a sign that the battery needs to be replaced. When they are bad the charger will not charge the battery, it flashes the red light to let you know it needs to be tested.
I am confident the battery is bad.
I use a battery analyzer, it takes 24 hours to test the battery and it will realign. if it can't it will show the battery needs replaced. I thought it was a charger when I got it. It is but much more.
:Agree:ThumbUp
I would do what everyone told you too do and if the cleaning of connections and a new battery don't solve the problem; well, it would be a good excuse to buy a new bike!:Coffee:
:(:confused::xzqxz:
Sounds like battery to me. When you are charging it even thoo it shows volts it may not have the amps. GOOD LUCK
Thank you, thank you and thank you to all of you who replied to my earlier post!!! :) You all were correct - I got my battery out and had it tested and lo and behold - no reading at all!:( Found the exact same one on line and had it shipped with free shipping (Throttex Batteries Co. ) :pepper: Got it back in the bike, after I cleaned the contacts with a wire brush and now it's purring like a kitten! I will always start my bike once a week and if I can't, I'll make certain to put it on my tender jr. Merry Christmas and Happy New Year to all:Santa::Santa::Santa::Santa::Santa::Santa::Santa::Santa::Santa::Santa::Santa::Santa::Santa::Santa::Santa::Santa::Santa::Santa::Santa::Santa::Santa::Santa::Santa::Santa::Santa::Santa::Santa::Santa::Santa::Santa::Santa::Santa::Santa::Santa:GYPSYGAL
Glad to hear you got to the bottom of it. Bike batterys are funny and when they die they often die differently than car equipment. I had one die on me on my Wing one afternoon after parking it for less than five minutes. When I turned the key on it was deader than Nixon. It was like the battery was gone from the bike, but it was there, just dead. That is the reason I change mine out every three years just to be safe. I don't want to be on a trip out West and have it die and I"m stuck 100 miles from somewhere I can replace my battery. I tender mine now every couple of weeks or so since riding this time of year where I live is rare at best.
Stockville69
Stockville69
