dragging pipes and hitch on Hannigan 2012
Jul 13, 2015
20
4
Murray,KY,USA
We have a 2012 w/Hannigan conversion. We love the ride but have one issue with it. We drag the end of the pipes and hitch when going in and out of drives and over speed bumps. Has anyone else had this issue? If so, is there a easy fix with out loosing the ride?
Thanks much for this Post.
As with any Unit like our Trikes (or any other Manufacturer of Trikes) that has a 77" Wheelbase and low Rear Ground Clearance. "scraping" is an unfortunate yet common Issue. It is difficult if not impossible to effect a true Solution without conversely creating another which may be even more displeasing.
The best Method to address the Issue is of a Preventative nature. Easiest & Simplest Way is to decrease the possibility of dragging/scraping occurring by altering One's Angle of Approach to the Terrain or "Obstacle". Try hitting the Curb, Speed-bump, steep Driveway, etc. at an approx. 30* Angle depending upon the Obstacle itself. Doing such will usually avoid scraping/dragging all together or vastly reduce it from happening.
Hope that helps and will prevent or reduce the scraping problem you are experiencing.
All the best to you and we do thank you for your Post and your ownership of a Hannigan Trike
ThumbUp
Thank you for the reply. I forgot to say this is a 2012 Goldwing w/Hannigan Trike
ThumbUp
Thank you
Maybe I've been lucky, I haven't drug anything on my 2012 Hannigan wing. But then I was schooled early on when I had a Triglide, out of the box that sucker drug its tail often. I had to put a lift kit on the Triglide to make it stop. I learned as Hannigan put it, alter my approach when I thought I might drag something.
joefontenot
joefontenot
