How do you know what rearend you have I have a 2006 GL1800 with a 2007 Kit what would the brake pad Numbers be for this
Lanny
Lanny
I have the rotors in stock @ $400.00 pr and free shipping to CONUS.
The manufacturer is Wilwood but they are only available through Lehman (Champion). I don't have the number here but will forward it when I get to work. 4am here..... I also have brake pads $34.00 per wheel plus shipping. These are EBC pads FA314SV available at most aftermarket bike shops.
Lanny
Looking for light bar and Aqua boards for 1500 goldwing Lehman GTL
Please send Picts and price. Thanks
I'll chime in here with some info. Many times if you need info such as you want youre better off calling the tech line. Theyll give you the info you need and if they cant answer your question right away theyll take your number and call you back. When you email a lot of these trike companies the email goes from one person who gets the emails to the one who has the info and then they get back to you. So sometimes it might take a couple of days or more.
I was once told by a rep that "If they really needed the info right now they would call rather than email!" so take it FWIW. Your rear end in your trike is a Ford and you can get seals,bearings,gaskets and u-joints at your local auto parts store. Unfortunately my parts diagram and blow up is on my other computer along with the link.
I have a 2002 Goldwing with the Lehman trike kit..I'm looking for a trailer hitch..If anyone has one for sale..please let me know...
The bearings for the Ford differential that was used in Lehman trike are not available from Ford. That Ford differential was from a Pinto, Bobcat, Monarch etc. I had to replace all the differential bearings in my 2000 Goldwing trike with a Commander kit on it. The trans shop had to hit Bearing supply houses for bearings. They were able to match those bearings and re-do the differential. I do not know when Lehman or Champion quite using those Ford differentials
Actually, anyone who needs bearings can go to a bearing houseto get a match for those bearings for any of the differentials used in Lehman trike kits. Much cheaper at Bearing houses.
handled !!!ThumbUp
Hi, LeeI have decided to chime in with an announcement. Many Lehman owners are having difficulty contacting the factory to get parts and or part numbers, answer to maintenance questions and general information on their Lehman Trike. Since the company is now under new ownership and many of the old employees have left, there is a lot of information that left as well. Many of the models prior to 2002 are unknown to the existing Lehman company representatives and therefor the understanding of particular parts for these models is also missing.
I have been a Lehman Dealer since 1998 and have serviced and re-built models that date back to the mid-1980's. I also have a number of wear related new parts for these older dis-continued models as well as part numbers for the ones I don't stock.
Post a question or comment and I will do my best to solve your issues.
