DK Custom PROJECT TRI-GLIDE Report w/ Lots of Pics
Kury mud flap
Kevin, I like the LED lighted mud flap. Did you say they will be lights, brake and turn signal LED's?
It looks like the kury mud flap mounting would cover the HD mud flap holes once removed, I hope. DJ
55il
The Kuryakyn mud flaps use the two holes already there from the Harley mudflap. You would only have to drill 1 hole. Kuryakyn has this in the instructions that come with their mud flaps
Yes, they are Run-Brake-Turn. I will be getting some pics & video outside, during day and night this coming week.
As bronxbill noted, these mud flaps use the to HD mud flap holes, making the switch easy.
Great job on those mudflaps - sure hope you can come up with a way
to de-chrome them though......
:Shrug:
De-chroming them is easy. We already pulled out the chrome strips and replaced them with LED's. The top chrome piece is stand-alone metal before installation. So it would be easy to rough it up and paint or powder coat it.
Wiring
Kevin,
Is there any problem wiring them in? I know a lot of the things on these newer bikes are run thru the Can-Bus system and didn't know if had a module for that or just paralleled the existing lights/LED's. Looking forward to DK putting them up for sale.
Thanks,
Kevin,
Thanks,
That's a CANbus TG it's installed on. Running right off the same wires feeding the fender lights. No problems, no error codes.
This morning was a light rain when I left for the shop, but it was sunny and 60* when I headed home.
Great day to test out the Mud-flaps.
Here are a few pics in the morning, before I left.
I really like how they turned out!
They did their mud-flap thing in the wet gravel and rainy roads.
It definitely felt good knowing those four bright strips of light were doing their thing when braking and signaling when I got in some traffic. Hard to miss.
Here are a couple of shots in the shop parking lot...took these before taking the long twisty route home. :)
Only got about 100 miles on them so far...will subject them to some more abuse to make sure they are solid.
When we were visiting Fuzzy last summer he explained to me how much better it was to have an extended & lowered brake pedal.
A month or so ago I installed one on my Softail. Whoa! Added floorboard room was a plus, and it was a HUGE difference in comfort, speed and control in braking.
I just installed an extended and lowered brake arm on the TG last night, so today was the first time riding with it.
Just like on the Softail, it is a big improvement in comfort and makes braking more natural, easier and faster.
Here are a couple of pics.
Got a couple hundred more miles on the mud flaps. A lot of it in the rain. Still looking good!
Running lights are nice and bright-
Brake lights and turn signals are crazy bright...probably enough to catch the peripheral vision of a texter. :)
Below is a video of a walk around the TG showing:
UP FRONT
Stealth LED Driving Lights mounted on the engine guard
Stealth LED Running Lights/Turn Signals mounted around the forks
Running Lights/Turn Signals mounted Inside the fairing vent
RIGHT & LEFT SIDE
Running Lights/Turn Signals mounted inside the Lower Fairings, and plainly visible from the side
IN BACK
Run-Brake-Turn LED integrated into the Mud Flaps.
Click HERE to see the video.
I to hope you move along quickly on these. Spring is coming quick. The extra lighting would be a huge saftey factor for all who install them. I hope to be placing the order soon! Thank you for DK's R & D work.
Tomorrow is Project Tri-Glide day for Devin & myself.
I've been riding all week, trying to break these...lots of rain, burn-outs in gravel, etc. They are holding up well. I think we will get started on them soon. :)
Devin is having ACL surgery next Thursday, but hopefully we will get it drawn up and get the laser work done before then.
If not, it will be about a week after the surgery until he is up and hobbling around.
Today we spent some more time on the Tour Pak bracket we've been working on.
At one point we had given up on it. There are several more odd bends in it that it seems at first glance.
But we are back at it with a new plan!
Here's notes that we have made to supplement our CAD/CAM drawings. :laugh:
After that we removed the prototype Oil Filter Relocation and prototype oil cooler.
I've been running the prototypes for close to 4000 miles, and almost 2000 miles of that was running the 68 mile test run route, over and over again. lol
It was nice to finally be installing a finished product.
I opted to go with the braided fiber lines, and black hose finishers.
Here's the adapter, where the oil filter normally goes-
The first part of the bracket, under the left passenger floorboard/peg-
The second half of the bracket, prior to install-
Installed-
With oil filter-
Never again will I have to deal with a messy oil filter removal!
Plus, our tests with the oil filter out in the wind, we consistently saw 8-10 degree drop in oil temps, and accompanying 3-5 degree drop in engine temp. :)
Next was installing the oil cooler. Not a lot of places for it on the Twin Cool.
This bracket places the cooler directly behind the lower vent. Those two (angled) holes in the bracket channel a surprising amount of air thru to the cylinders for cooling.
Here's the oil cooler installed.
Our tests with the oil filter/oil cooler combo consistently saw a 30-34 degree drop in oil temps, and an accompanying 5-7 degree drop in engine temp. :)
I am very happy with the results. *
Tomorrow I'll be cleaning the TG up a bit and then taking some pics out in the sun.
Kevin when you shoot the new pictures can you please shoot a couple showing more of where it is mounted from further back. to see the over all look.
Installed-
With oil filter-
UP FRONT
RIGHT & LEFT SIDE
IN BACK
I CAN SEE YOU!!!!!!! Very nice....and effective!!! ThumbUp ThumbUp ThumbUp
Installed-
With oil filter-
Hi Kevin!! Any idea when remote oil filter system will be for sale? And can you possibly provide a pricing range? Really like the remote filter idea and would consider installing one on my Trike!!
:pepper:
Thanks Kevin!!
Roger
Here's a pic of it from further back.
You can see more pics and a full description at this LINK.
:pepper:
Thanks Kevin!!
Roger
Just got it on the website a few minutes ago. Normal price is $174.95, introductory price is $154.95 for the next week.
You can see it, and the Dual-Cool Oil Cooler at this LINK.
Roadrunner1
Roadrunner1
