I see you are not too far from me. Where do you buy this stuff ??
Probably from "slamming" the trunk door closed!! Mine broke the plastic that holds it in and I just had a new lock installed and adjusted by the HD Technician and now all I have to do is push it shut and press with the palm of my hand and it works better than it did new (2013 TriGlide). Also during the experience we ordered a new "black plastic" housing that broke and fixed the existing OEM lock. When mine finally broke, the push button came almost out and I just took a hold of what was sticking out and it came out very easy.
Bottom line, "do not slam the door closed" as the plastic that holds the lock in will not take it. If you have to slam the door, use a small amount of WD-40 and continue to close it easy and press to latch with the palm of your hand. Works for me anyway!!!
Roger
Excellent advice....the trunk lock on my 09 TG literally "flew" across the garage floor! Yes, I was slamming the door shut. After HD tech instructions, I gently close and lock trunk.
On my '13 I push on the trunk 'til I hear a click than push hard one more time 'til I hear a second click. Then lock it.....no problems with it coming open. Think 'slamming' it would bread something..
8~\o
I guarantee that "slamming it" will eventually break the plastic that holds the lock set in place!! Don't ask me how I know!!
Roger
Had lock replaced and adjusted under warrenty. Will see if this works
That makes two of us :AGGHH:....bet we weren't the only ones.
My 11 Tri's trunk when it was new would pop open '' After the second time i very carefully adjusted the latch pin [spade] and it hasn't opened since then... Once last summer for the first time i locked the trunk' and it took a heck of a time to unlock it... That was the first time i ever locked it and the last... Probably dirt got in it...:Shrug:
For people that lube their locks, is it from the front or back?
