2009 stallion
Good luck
this same thing happened to Terry at the trike rally in deadwood. it looked like the screws holding the mount in place were tightened too tight and finally just broke off. I did not hear what he had to do to get it fixed. maybe fiberglass it permanent.
Dragon
headlight
Hi,
As Dragon said, Ive had the same thing happen to me, Twice. Both times I ended up with getting a replacement housing from Texas. Takes awhile to get it but that's the way it goes. Tried several shops to get it fixed but no luck. Both times were the result of very bad potholes, once in Alaska and the last time in south Dakota. Good luck with yours. Terry
Head light
I repaired mine with epoxy then build around the post to reinforce. I had to remove the hood which is easy. With hood open remove the mirrors then unplug the head light, remove the Phillip's head screws that attaches the skin except the ones at the very front, close the hood then remove the screws at the very front, then the hood slides off. I hope this helps. #697
Tom his "09" maybe a fiberglass body. Still I think the best ave of attach is to remove the hood makes things easier to work on. Then I would guess epoxy or fiber glass the new assembly in place. Call me if you think I can help.
Thanks Ted, I spoke with Danny yesterday and I will be getting together with him to see what he has. He said a new painted hood has been ordered along with the headlight assembly.
Tom
Tmorri1
