Dreaded CSC Driveshaft Failure
The splined shaft had slop and bone dry when I got it. Which is why I put the 3rd shaft in being one from Mountain Trike. It's got no splines and grease zerk at rear. Only have about 3200 miles on it. Hopefully someone will need it or add it to my other parts I replaced or upgraded. Lol
I'm glad to hear some are upgrading their shafts. Their new shaft design is solid with no splined sleeve in the middle. I believe both u-joints are replaceable, and the front one is larger then what they've used in the past. Unfortunately, because the shaft has no splined sleeve, that means it is no compressible and able to be easily remove for an inspection or service. However, a shaft without a splined sleeve should last longer and be more trouble free. I'd bet a new shaft will provide a smoother ride too.
can you explain that highlighted portion please. I'm missing something somewhere. Thanks
Yes ... on most, if not all with independent suspension, the distance between the engine and the final drive unit stays in a fixed position ... it does not move up/down like a solid axel. That means that a solid shaft, or fixed-distance-shaft, can be installed with u-joints on both ends. It's my understanding, that because it's a fixed shaft, to install it, either the engine needs to be pulled forward, or the final drive unit shifted backwards, or downwards, in order to get the shaft in or out.
Road Smith uses a similar shaft but theirs has a sealed splined sleeve in its middle. This allows the shaft to be compressed just enough to pull the rear part of the drive shaft free and clear, so that shaft can be slid out for an inspection and service.
CSC Drive shaft
With the new style CSC drive shaft, the plate that holds the differential is slotted.
That way the driveshaft can be removed.
The four bolts are loosened and the differential is pulled back so the driveshaft
can be removed.
On the early new style kits, the differential needed to be pulled back to change the
differential oil.
Im having a difficult time grasping the fixed shaft coupled to a differential with suspension. Wouldn't each time you hit something to cause your suspension to collapse to actively cushion the blow cause a lengthening or shorting in the distance between engine end and differential end?
Greg, could the problem be sub standard parts as splined expanding drive shafts are used in almost every other application out there including severe service equipment to high mileage over the road trucks that are loaded with 80,000 lb one day and nothing the next. Point here being drive line angles......
Ive got to do so more reading.
Thanks for being patient.
Most of the final drives are fixed to a subframe that's attached the bikes frame and the distance between the engine and final drive always remains the same. Coming out of the final drive on each side are 2 CV shafts. The CV side shafts are what swing up and down supported by the rear suspension. The CV shaft assemblies are what allow for extension and contraction as the tires move up/down.
As for sub standard parts. It's more of poor design. There is nothing wrong with having a splined sleeve allowing for expansion and contraction of a shaft ... but it needs to be sealed and not like the video. You will see that the male end is dry and open to the elements.
I guess I'm still trying to figure out why a device (drive shaft) that's used in nearly every instance where the power source is mounted apart from a transmission or differential is such a source of problems in a trike.
Greg, Thanks for your informative replies to my questions. I'm going to do more reading and talking to my mechanic brother. We're headed to Lima Flat Track tomorrow so we'll have plenty of time to talk. Those Indians are really putting it on the H-D's. Kind of sad!
To all the other boards members who just wish I would go away and leave it alone, Thanks for bearing with me while I try to grasp this.
It boils down to cost $$$$$, and it being a competitive market. I'm sure a shaft like RoadSmith uses is several hundred dollars.
Finally got out to ride our Goldwing 2010 CSC Trike after having the driveshaft changeover kit done by A&L Trikes in Rapid City, SD. He did that and changed our lights over to LED's, tightened up the bearing on our front forks, and did an over all service of everything. It now has about 9,000 total miles on it.
What a difference it has made getting everything done to it. No more thumping or vibrations and it handles like a dream after tightening up the front fork bearings too. Goes into a curve like it should and like i said it is a totally different trike! Can't say enough about AL as he is very neat and meticulous as you can tell by the inside of his shop! We put 120 miles on it the 4th of July and really enjoyed riding it.
Can't say anything about the gas mileage yet as we drive really conservatively and mileage seems to be pretty good. We are going to be at the Trike Rally next week in Deadwood, SD. I think it starts on July 10th if i remember right. Google Deadwood Trike Rally to get info on it. Will try to check the mileage out and post it back on here in a couple weeks.
If someone needs the gearbox we took off get in touch with Al. I left it with him as i won't be using it ever again!
Good to hear about all the improvements on your trike. My 02 is at Neihaus in Litchfield IL. They got the update or retro kit as they call it installed. They also installed bushings on rear that were not there originally and should have been. The side panels now fit perfect and fenders were lose as well but I never noticed any movement in them.They found my steering head bearings were bad also, Having them replaced as well.
Feel very confident in it will finally perform and be as it should when I pick it up. Neihaus has installed over 1200 trike kits with they're tech Roger having done most all of them. He has in 30+ years with them
I am at CSC yesterday & today having mine upgraded. My trike had developed a loud roaring noise that started about 2,000 miles ago and continued to get louder and louder. When Will got it disassembled one of the barings had gone bad, the gear box was full of metal shavings. Glad I came when I did, it was near leaving me stranded.
I once was hired to managed an automotive repair shop that had the worst workmanship, or craftsmanship, I'd ever seen. At the time I told my friends that "in my worst nightmare," it could not be as bad as I saw. It was a large chain, and after asking around, I realized that what I was witnessing, at least for this chain, was common. After 6 weeks, because of it, I left.
In the GL1800 world, I see a lot of the same.
About how many miles was on your old gearbox version? I had 40k on mine when front seal began leaking. When I started adding gear oil every 600 miles or so it was time for Retro kit
29,800 mi. Everyone as CSC was super nice to me while I was there, kept me updated as to what they were doing and eta to completion. I am a customer of there's for life.
Yikes, in my humble opinion a gear box should not fail at that low mileage, thought CSC had that problem resolved? Hey Greg, welcome back to the real world from the BRP riding experience. Some folks missing you over on the 'other forum', some good words for you and your work.
Invite them over here Bill. A few drama queens ruined that site, tried to ruin this one. I didn't wait as long as they did to clean house.
Dwight and the whole CSC staff are a class act company. I've seen them go above and beyond what they were obligated to do to take care of their customers. Dwight was an employee for many, many years and is now a partner and is serious about taking care of his customers. I have frequent conversations with him and can tell you he is on top of his game.
Right on Zook and copy that. Not my fav place, but I go there because there are nuggets of good information occasionally. See ya in Maggie.
You are correct, there are "nuggets" of info there. Unfortunately for the DIY's, most can't tell the difference between a good nugget and a bad one. I've always advised all to ask a poster if he has personally done what he is recommending other do. Unfortunately in doing such, it can expose an angry arm-chair-quarterback, and his attacks can start. Sometimes, the "advise giver" will have many screen names, and his other screen names will jump in and support his cause.
Long ago I discovered there were only 2 individuals who I could count on for advise. Max from Traxxion, and Rob (Techdude). Both are professionals in their own fields. Behind the scenes we are always exchanging info regarding GL1800s.
Thanks to Papa Zook this site is well monitored.
Thank you:)
Yes ... such failure should not happen so quick. They had a great idea, however it didn't work out well. What they were attempting to do was to make the drive shaft more inline with the output shaft of the engine. To do that they added a "transfer case" like one would see hanging off the side of a 4-speed transmission on a 4x4 PU in the 70's. The one used by CSC is much smaller and inside it are planetary gears instead of a chain belt like a transfer case has. Instead of "transferring" power to a forward differential like a 4x4 needs, CSC is effectively adding additional gears to space the drive shaft more rightward.
Roadrunner1
Roadrunner1
