91 v cycle headlight
hi im looking for a new headlight sealed beam for my 91 v cycle runabout , talked to the builder a few years ago and he said they were out of a honda atc with bulb replaced with a automotive hi/low bulb , he told me he had new ones for sale and now i need one but have found that he has gone out of business , his daughter had a trike shop in daytona but has gone out of business also , sealed beam is 4" x 6" , would prefer led , does anybody know what i can fit into my headlight bucket ? thank you david
I have KC lamps from the mid 70's on my trike, will up grade them soon. I would like brighter LED lights myself.
I will be taking out that rectangular style light and just putting a round one in it's place, also to match the body design.
Did you look at a Honda dealer to see if one could get you a replacement, might have one the same size that is newer and brighter, the thought hit me, LOL
Very nice looking trike David.
MR TRIKE
you might try roadsmith. they were v cycle before they became roadsmith
Hello- Nice Trike- The chrome headlight frame and glass lens is from a mid 90's Honda ATV. I made a mold to hold the frame for the trike. It came with a single element bulb so i replaced it with H-4 60-55 watt auto headlight bulb. It had to be held in place with high temp silicone to work. You can replace with a 100 watt-55 watt "weed burner" bulb or they now make a direct replacement LED for H-4 applications.
You can use that one but make sure you get the new bulb in same position as old one as that is what directs the beam of light in right direction. I would take a picture of old one before cutting silicone out. The 3 tabs on old and new bulb must match. Silicone the new bulb in place and let dry overnight.
I also recommend using your 2 quartz running lights as an aid and safety need. KEEP-ON-TRIKEN I know these facts as i was the founder and builder of these trikes for The Trike Shop now Roadsmith. Still the Leader in the Industry!!!!
thank you , i have changed the running lights to led much brighter and less strain on generator , i talked to a man that his daughter had a place in daytona called the trike shop now closed , anyway he said that he built this trike and he had new headlights for $50.00 if i wanted one , i should have bought one for a backup then , biggest problem is the chrome is in bad shape and doesnt reflect the light very good so i was trying to find this person to see if the headlights were still available , i have found the 1985 honda atc110 with same headlight on ebay but they are in worse shape than mine
Hello - we have the headlight in stock at our Minnesota location. Please call 800-331-0705 and we can get the headlight shipped to you. The price for the lens with bulb complete is $50.00. Ask for Jim
Thanks!!
HomeFree
HomeFree
