reverse motor out again
Jack....You could have it rebuilt ....Or have a mechanical reverse put in...I Had an 11 Tri-Glide and i used reverse a lot ...And i got tired if monkeying with it.. 3 times...Once i put the mechanical in i found out there wasn't any parking spot where i couldn't back out of, Just like i could in a car i could park nose in down hill ,in gravel , grass , and back out of..
My buddy from Paducah had his 2014 rebuilt a couple years ago for around $60.00. I forget where he said he had to ship it to for the exchange. He said it was very easy to change out.
Hey Jack, do you know what the revision on this motor is & or what the difference between 09 & 09A?
Also, are they the same for the Tri-Glide & Freewheeler?
Thanks:Dorag:
Not a clue on the part number change Up til recently HD replaced the reverse motors, now the techs are rebuilding them in house
The trikes share a common reverse motor
  • Like
Reactions: MDO
Michael, there is another updated part number for this motor that ends with a B suffix
The replacement motors now have a vent hose much like import starters do This keeps moisture out of the starter and helps internal heat ( bad JU JU) to escape;)
  • Like
Reactions: MDO
rvflorian
rvflorian
