Thinking about adding slipons and a Power Vision and maybe an a higher flow air filter that will fit under the stock A/C cover. Already have a catless S&S header and am running Vieds. Also have a DK external breather and will be adding Mighty Mites. Just looking for a little more low/mid grunt, a little deeper rumble but not loud & a cooler running engine. Already have DK tank lift & their air deflectors.
So, questions are:
Will a K&N air filter in the stock A/C give me enough air for this slight stage 1? Seems like a more open A/C will will just suck in the hot air from the Mighty Mites. Thoughts?
Anyone running the 4" Reinhart slip on mufflers? From a bunch of you tube videos, I like the sound. They don't seem too load unless you get on it. I had V&H Twin Slash tru duels on the Switchback I had prior to the Tri. They were fine, but wouldn't want it any louder.
Also will the 4" cans be an issue with dragging ( I do have the DK 14" rear shock setup)?
Thanks in advance!
So, questions are:
Thanks in advance!
