Just got my 606 with Traditional EBS in the mail for my 2017 M8. Really high quality parts. One question....
The backing plate is stout and heavy. So, when installing the backing plate on the throttle body, do I leave the 16400049 Induction Module Bracket in situ and replace the OEM breather bolts with the DK breather bolts and banjo fitting to provide support for the AC? Or did I miss getting a bracket that I need to hold the AC assembly up?
You are good to go with your kit, the breathers bolt thru the existing bracket
This is the AC I have It works great:clapping:
Jeff, if I remember right Kevin and Devin tried all their air cleaner set ups on my M8 to see how they stacked up
The Outlaw AC did the best job
I like it , it tucks in nicely giving more leg room
Kudos to D K Customs in their quest to bring to market the best of the best:clapping:
Yep, that was a long, loud day on the dyno with your FW.
Actually the Outlaw 636V out-performed the Outlaw 606 by a bit, but you did not like the forward facing look, so went with the 606.
We have a bunch of charts of your Freewheeler on our site at this LINK.
That was a good time man. And you saw the nitty gritty, grind it out, sometimes boring work of putting together prototypes.
Appreciate your patience & help!
I like it , it tucks in nicely giving more leg roomKudos to D K Customs in their quest to bring to market the best of the best:clapping:
Did you go with the Traditional EBS or the catch can? I went with the Traditional set up so it is purposely visual and folks can ask "What the heck is that" and I can say "An induction earing.... don't you have one?"orag:
I have a design all my own It uses a catch with a drain cock I drain it once a week, getting brownish colored oil and water coming out
Interesting... I guess I better tape a Dixie cup to my cam cover to catch the drops.....
If it gets bad, I can always go for the catch can with a Klarich valve as an upgrade (Yes)
