Could you post some pics please. Also, I would like some info on your 3" shifter pegs, like p/n's & where you got them from. Thanks
LA Choppers sells a couple of different 3-3.5" Pegs (The picture below is their Extended Delrin Shifter Peg P/NLA-7200-00B) as well as a shifter peg extension (LA Choppers P/N LA -7201-00). Pingle also has a shifter extension that puts the shifter length at 3" (Picture below) Pingle P/N 62167. I had the Pingle one but kept hanging my toe up on it. I am not a heel toe guy, so I am sure it would be different for somebody who is.
Stereo Upgrade
I had a handlebar mounted stereo system on my FW for a few month - Just didn't perform very well - So , I bought a 180 watt unit ( 4x45w ) that came with ( 2 ) speakers - I used the other ( 2 ) outputs to run 3.5mm headphone jacks for our helmet speakers - Unit really performs well - It was easy to mount on the on top of the fork cover down under my windshield bag - Speakers look good an sound good - FM Radio picks up stations nice - Even came with a lighted remote ...20190326_182014.jpg
When it warms a little more, I am going to drain my clutch & differential (currently using Lucas 20W/50 high performance full synthetic motorcycle oil) and give HD Formula + a try. I have 2 quarts of it I can't return & want to see how it works over the summer. I will say I am very happy with the Lucas. I am also going to try Castrol Actevo 20W/50 in the engine over the summer.
In the fall, after my 2,200 mile round trip to the 4-Corners Motorcycle Rally (Labor Day Weekend) in Durango, CO, I will drain all 3 holes & give Redline a try.
Drain fluids
s-l1000.jpg Differential.factory sealed. Do you mean primary clutch housing?:)
Tomorrow is the day for my oil test. After a fun warm up ride, I will drain all 3 holes & put HD Formula + in the primary & tranny & I have Castrol Actevo 20W50 oil for the engine. After about 4 to 5,000 miles, I will be back to Lucas & Red Line after this experiment. :)
I am really looking forward to trying the Redline Shockproof in the tranny. It has a great reputation.
Tomorrow is the day for my oil test. After a fun warm up ride, I will drain all 3 holes & put HD Formula + in the the primary & tranny & I have Castrol Actevo 20W50 oil for the engine. After about 4 to 5,000 miles, I will be back to Lucas & Red Line after this experiment. :)
Put the Redline in NOW:p
  • Like
Reactions: MDO
Oil change
You do realize I was only busting you stones on with differential picure.😮
No problem , I can handle it.:cool:
You're bio said you're retired military, I did 25 years state law enforcement. I learned early on, if you folded under some ball busting you brought down a world of hurtin on yourself.
Sissy bar
After bending the stock bar an installing a wrap around arm rest setup ... I have made arrangements have the bar extended about 18" up for cosmetic appearance ... This will also give " Sweety" and hand hold for climbing on an off - I will post photos once done.
You will never look back;)
I got all done with the lube changes. On my warm-up ride I went to my dealer (Doc's HD) to get a derby cover gasket.
I figured I had never changed it and would be nice to my baby. They only sell it in a kit with the 3 drain plug "O" rings, which I don't need, as I bought a 10 pack from the hardware store. Doc's gives me a 10% discount on everything, so it was only $5.30
Back home, after pulling the plugs, I pulled the cover and the gasket looked great, then I remembered that it got replaced at the end of the year during the clutch recall. Oh well, now I have a spare & I got a cup of coffee out of the deal.:Coffee:
The drain plugs for the engine & tranny looked great, along with the Lucas oil, the primary plug & fluid looked nasty.
I guess it's the material from the clutch plates.
They had all the new colors on the showroom floor & I like that denim red.
They also had a used 2017 (black) with 725 miles marked down to $21,000
Overall, a fun day, but storms are coming tomorrow, so I will have to wait till Saturday for a test ride.:Dorag:
one other thing, I could never see the Lucas on the tranny dipstick, it was hard to read...That is not a problem with the Redline.:cool:
I didn't retire from the Navy (Submariner), just a bit shy of 11 years of service, with over 18 months under water.
We were professional ball busters.:D
I figured I had never changed it and would be nice to my baby. They only sell it in a kit with the 3 drain plug "O" rings, which I don't need, as I bought a 10 pack from the hardware store. Doc's gives me a 10% discount on everything, so it was only $5.50
Yup, I ran the Lucas gear lube just for grins once, could not see it on the stick
@ the next oil change I switched back to Redline;) I am sure Lucas is a gear gear lube as is their oil My local HD dealer is now selling Redline ;) Cycle Gear stores also carry Redline
  • Like
Reactions: MDO
Stockville69
Stockville69
