I'm thinking about running a sidecar and a car tire on the back. Size? 2003 Dyna
I'm looking at sidecars and I hope to have one on my bike by spring at the latest.
I want to run a car tire on the back after I get the sidecar but I don't know what size tire works with a 2003 Dyna.
Doe's anyone run a car tire on a 99-05 Dyna?
What size worked for you?
Use this put in you bike tire size, then start comparing it to some car tire sizes soon you know if there is one close.
Here is an example chose the over lay to compare. In the posted one it may be to wide keep looking you may find one that works
https://www.tacomaworld.com/tirecalc?tires=150-80r16-195-60r16
That size may work with a chain drive conversion.
I'm not sure if it would fit with the belt drive so I will have to do some measuring.
I posted that one as an example more research may turn up a better option. What is you stock size tire?
Look at a 175/60R16 but avoid run flat or so called wheel protectors tire they will be slightly wider.
