2018 front brake bleed
Brake bleeding
According to 2015 trike supplement bleeding sequence is:
Front- left - 4 oz.
Front-right- 2 oz.
If you continue to do rear brakes :
Front - left (lower bleeder) - 2 oz.
Front - right (lower bleeder) - 4 oz.
Rear left - 4 oz
Rear right - 2 oz
** Torque specs :brake caliper bleeder valve front: 80-100 INCH lbs
brake caliper bleeder valve rear : 31-33 INCH lbs
Rear bleeder valves are much smaller than front.
******** This is for a NON-ABS SYSTEM**** Best to check with someone who knows if abs front is same otherwise you may cause damage to system??!
hi wondering the right way to bleed front brakes on tri glide
thanks gabe
Gabe, you really need to get a service manual. It will help you in answering numerous service questions.
Well worth the small cost. I got 1 for my Freewheeler in PDF format & I love it.
You can print out what you need for a particular service and even load it on a tablet.
PDF
shaker
I've checked the numerous sites for downloading, listed on several forums. Maybe it's just me, but it appears Harley has taken away access to their bikes/trikes
Sequence
true do you use the top or bottom bleeder
thanks
What i had posted earlier is taken verbatim from the manual. The top bleeder is for the front.
The numbers are the amounts of fluid you should draw from each bleeder.
Then the sequence indicates the lower (bottom) bleeders are connected to the rear master cylinder.
If only doing front brakes and front master cylinder use upper/top bleeders
thank you ever much
gabe
shaker
I noticed they were removed from the site I got mine from, Service Manual Warehouse.
Jack had mentioned a site a few weeks back, but I can't locate it.
Pdf
When you initially posted the site addresss, i checked it out and all Harley manuals were offered for purchase. About 2 weeks later when i finally decide to purchase one, they were taken down.
Bleed front
thank you ever much
gabe
Use a torque wrench to tighten. Remember, bleeders are virtually hollow tubes and can and will twist or break off. And are a pain to drill out.
I know a thing or two, because I've done a thing or two😮
There are two bleeders per caliper - upper for the front brake and lower for the rear brake. Been that way since the reflex linked brakes were introduced in MY2014.
The problem I'm seeing is that the bleeder screws are inboard of the caliper. I can't see how to get a wrench on them to loosen and tighten. If anyone has done it or knows how a service technician does it please let me know. I'm thinking the caliper would have to be removed from the fork and bled off the bike.
Jerry, I just did my 17 Freewheeler front linked brakes, I used a wrench like this with no problems
I always crack the bleeders loose before taking the calipers off
I really don't like the plastic brake lines much, make sure to support the caliper when removing it for pad removal
  • Like
Reactions: MDO
Thanks for the info Jack. Still a bit confused. Did you have to remove the calipers from the fork in order to bleed them?
I bled the front circuit of my 2017 Freewheeler, like Jack stated & I didn't remove the calipers. Do the left side 1st, then the right. It's not hard, but I use an in-line check valve right off the tubing that goes on the bleed screw. It keeps air from re-entering the brake circuit. The check valve was made by Motion-Pro, I believe. It was around $10
1 word of caution when working on the front linked brakes
Be careful when removing the calipers
Unlike brakes from before, these calipers have hard plastic lines instead of the rubber ones you may be used to seeing
They are not as forgiving, support the caliper at all times, do not let them hang free
4spen@Proj2
