Just dropped the trike off at the dealers to get the primary vent installed. They did not give me any trouble at all and said I could pick it up tomorrow. My question is will it work and can I use the fat shaft from Greg Williams with the vent installed?
Interesting ... haven't heard this happing on the 19's .. good luck with the vent.
I wouldn't change anything else until you know how the vent works and your warrantee is up. Just MHO.
I learned something here as I thought all the 2019's had the fix from the factory.
I still don't understand the relatively small number that do it & why they all don't
I have not heard of any Freewheelers transferring, yet this in itself seems strange as the hydraulic clutch is the key factor IMO
My 15 never transferred any fluid and I rode it hard
The last trip I took on it was non stop from Jacksonville to Mn, stopping only for fuel and a snack
My 17M8 has been ridden hard and spent time on a dyno, it today has not transferred any fluid
I think you and I have GOOD ones
Early build dates did not have the vent installed by the factory
This IMO is still a band aid fix ( it does seem to work), However Harley is missing why this is happening.
If you look at what they changed when they went to a hydraulic clutch you will see why they transfer fluid
Keep a close eye on your fluid Alan, your trike has been identified as one that may transfer
I sure do hope the vent works, I got a lot of time invested in this thing. I bought my first new Harley in 1970 and this is the first one thats had a problem I didn't cause myself.
I thought it was just the M8's that did this? Mine is a 14 103 Water Head.
Finally had to go out and check my tranny level ... a tad over 4k on the current Red Line with Shock Proof ... Still pink bubble gum and right at the mark I left it ... so ... so far .. no migration .. ... I am in the habit of not checking the tranny very often ... but I will now ..
I have two friends with street glides ( non water cooled) and they are both doing it.I work with a guy who traded his 18 Road Glide on a new Indian because of oil transfer.I have yet to see any 19's that have the vent factory installed.Will be interested to see if the 2020's have the vent.
