battery
Dragon
250+ Posts
Dec 28, 2010
288
72
oly,wa
Good morning
I need to replace my battery again. just wondered if anyone has found a battery that holds up to the abuse it gets under stallion. my last 2 lasted 3 years each which is pretty good. I picked medium priced battery with 2 year warranty. does a cheaper one last just as long:drama:
Dragon
I went to Pep Boys and got a Bosch AGM. I figured being over the back axle it would get bounced around quite a bit. Nothing to slosh around in them. It's been in for 2 years and still working. Rick
When you get your new battery, buy a battery tender and also think about installing jumper posts in the trunk on the left back wall so it can easily aid in a jump start for you or others as well as connecting the tender. Tomg
Good morning
The battery gods have smiled on me. I purchased a duralast gold 3 year warranty. i
I still had 3 months left on warranty. They gave me a brand new battery:clapping:. now if i can only fix the rest of electric gremlins, digital display, cruise control don't work even after replacing master cylinder with new sensor, switches:blush:. oh well can't really go anywhere anyway:gah:
Dragon
Good morning
Check the cam on top of the cruise control unit. Mine was stuck and I couldn't get the cruise to work. I lubed it, broke it free and everything worked. I also had to replace the buttons on the steering wheel. They're not made to be out in the elements. Rick
Sylvester
Sylvester
