High speed wobble !
Mek5o
Gold Member
Gold Member
Apr 14, 2019
29
20
Cheltenham
What can any one tell me about what can cause high speed wobble? What i should be checking and how i can determine if its from front or rear ? it seems tome its in front but I work on cars for a living not bikes Lol !
Check your tire air pressures first.
18-20 psi rear and 36 psi front.
Your C-50 only weighs a little over 800 lbs.
Then take it for a ride.
In a C-50 some headshake is normal, usually below 20mph.
High speed shake (55-65mph) is usually wheel balance.
Since you have 2 wheels on the back, twice the odds one of them is out of balance.
Another suggestion to make it easier for you and others is to continue posting in the same thread you started originally so that all of the solutions and homework is in one place.
18-20 psi rear and 26 psi front.
Do you really mean 26psi in the front?
for others benefit can you advise what you did please?
Adjusted all tire pressure front to 26 psi rear to 19 psi. Also rechecked front stem adjustment found it to be to lose, in the neck, made that adjustment as well from 1/4 to 1 3/4. now it rides like a dream. Sweet and smooth !
ronjon
ronjon
