Looking at EBC rear brake pads, they have double sintered pads and semi sintered pads, those of you that have used these pads which did you use and what did you think of the performance.
I just purchased the EBC double HH front and rear for my 20 have not installed yet , stock pads have to much dust , I could not find Lydell that fit a 2020 ? I will install when I replace my two bent rear wheels, put them on the tire balancer a while back and I don't Know how they got that bent ? What sucks is I sent then out & had them PVD coated black chrome , which was not cheap .
Call them. I know they have for 2019, so I bet they fit the 20, maybe have not updated the list
checking EBC website "Harley Davidson Trike FLHTCUTG Tri Glide Ultra Trike 2014-2021
I would think Lyndall would fit also same years.
Are you sure you got your wheels back? Just sayin...
On my 20 the rear brake pads do not look like the picture Jack posted ? But I have not installed tem yet .
Dan, here is the EBC fitment
- Harley-Davidson®
- Trike Freewheeler FLRT : 2015–2020
- Trike Tri Glide Ultra Classic Anniversary FLHTCUTG : 2018
- Trike Tri Glide Ultra Classic CVO FLHTCUTGSE : 2020
- Okay I went back and checked tri glide brake post , the poster PTR has a2020 tri glide screamin eagle and wanted to to change pads the post was started on 2/6/20 he had a hard time to get rear pads , he ended up with part # FA631HH , if you look them up it say's that they fit Spyder's ? They fit 2020 tri glides also , I bought the one's you have pictured on ebay and they don't fit . check out that post you will see ?
Look @ part number Mfr Part #: FA641/4HH EBC rear pads
Mine are the FA631HH the FA641/4HH do not fit 2020 Look back at the post by PTR . check it out
