Need new tires
Well I'm a little different I run a Michelin Commander II rear tire reversed (reason being tire construction) and 205X70R X15 in the back. I changed the gearing going to the 70's to lower rpms at cruising speeds. Worked really well for us in Pennsylvania. Travel safe Fred
I run Michelins all the way around on mine
Good choice I most likely would have used them on back but I got a great price on my Goodyear's. Installing a 70 series just a little taller tire, I removed the screaming at 70-75 mph. I still have good bottom end. It was an experiment that worked out if it didn't my utility trailer had new tires.
Justwant to add a light car or mini van tire should work well. I would check for rain rating and quiet ratings. There are many running comfort tread good year's. I didn't need soft sidewalls with the suspension upgrade to Pro Action rear shocks. Good luck keep us posted. Fred
The ComfortTred tires are great in the rain & only enhances the ride with the ProAction.
The ComfortTred, is very good in the rain & enhaces
How much do you think it lowered the rpm by having a taller tire ? THANKS DAN
HomeFree
HomeFree
