I-Team: Lawsuits Blame Harley Davidson ‘Trikes' for Death, Injuries
Should we be riding these things ? Thats some scarey shit ? Can you unplug the abs module and still ride it ? You would think harley would say weather or not they are safe to ride ? They no theres a problem how many people need to die or be hospitalize for them to step up and repair these things ?
The problem is they put the guard rails to close to the road you can’t avoid hitting them they should move them out into the woods😱🤔😁..
Glad you pointed this out Bob. Sometimes the answer is just so obvious.:Shrug: The other thing they need to work on is telephone poles. They can jump from the side of the road in a heartbeat. Barely avoided a couple back in my younger drinkin days.:xzqxz::laugh: if I remember abs disables it self when a fault code shows up. They then are basically standard brakes. Jack will know.
[FONT=&quot]Traction control is automatically enabled at each ignition start cycle. The rider may choose to disable traction control anytime the vehicle is at a complete stop and the engine is running by pressing and holding the traction control switch for one full second.[/FONT]
ABS cannot be disabled, you would have to do a work around the pump system
The majority of ABS lock up problems were already fixed after HD first debuted ABS on model years 2008-2018
However 19 and 20 models also had a recall for a software problem
I just unplugged my two rear wheel abs sensor's . brake's still work good , don't have to worry , when you have a abs sensor go bad on a car you have regular brake's , I don't think mine ever worked any way's .
I'm Probally Crazzzzy I rode my trike all day today with the rear A B S disconnected so there is no A B S or traction control or RDRS It seem's to handle so much better It's a totally different trike it seem's like it's a easyer to ride and handle's better ? It Can't be posable ?
What about the sensor on the front wheel? Is that not linked thru the ABS pump?
Are there any codes besides the obvious?
I assume your ABS light on the speedo is on?
Yes A B S light on , traction control light is on, once one sensor is bad or disconnected the A B S is disabled .
tw0fast4u
tw0fast4u
