Tilt Steering
Yes indeed it tilts. Maybe you are not pulling the lever up (towards you) hard enough? Or, are you trying to go in the direction of a stop and it is already bottomed out??? Just a guess, it should work. There were some instances where the Stallion would not start if it was all the way up. If you ever run into a starting problem, try to move it down if it is up. Good luck.
tilt steering
You got it. I was not pulling the handle far enough. The pull amount on it is crazy. Thanks for the help.
wyldesydedavid
wyldesydedavid
