hi all i thought that the stallion was a ranger in disguise i tried to use fordscan and it doesnt recognise the pcm and quits right away asks if i have a special pcm if i have a code for it anyone else tried this new to me cheers
try reading the part number when you get at the module behind the panel below steering wheel. that number should tell you where it came from. then you should be able to see if it can be reprogramed keep us advised
What do you use to scan the OBD system?
Alvin says he gets an error message when trying to use a scanner, is this common with Stallions having propitiatory ECM mappings?
Good morning
I know rick you had yours done but the process can only be done if you purchase certain software to achieve success. by the way how does it run.
the code reader has a fuse under the seat see if that is blown, i had this problem.
My pcm came from a v8 van:xzqxz:
Dragon
Runs great. I get 30-32MPG up and down the mountains out here running at 70MPH+/-. If I'm on flat roads at that speed, I can get as much as 35MPG, but that doesn't happen very often. It's mostly around 30MPG. Yep, mine was from a V8 van and they were using half of it. If I remember right, timing was set at 10-11 degrees because of it being a van PCM and it was brought up to 21-22 degrees.
He thought we could get it up to 24 degrees without pinging, but I said I wanted to be conservative to keep it from pinging. The fuel mixture was adjusted and the shift points were slightly adjusted. It has 55000 miles on it now and it doesn't burn any oil between my oil changes at 5000 miles. If you remember, I did change the compressor, check valve and pressure valve for the airbags and I'm loosing only about 2 pounds if I don't start it for 2 weeks. I still love it. Rick
Where is the ODBII Port on the 08 - 09 ?
Tom
Tom
Tom........Welcome to Trike-Talk.......:clapping::clapping::clapping:...
tom under the hood right side towards the back of the engine under the bars. you really have to look for it
So what is the part number on the pcm? Anyone just swapped in one programmed for a ranger?
