I've spent most the afternoon on this & gone round in a circle.
The trike:
late 90s Vmax with English axle (MK1 ford escort). Compomotive 15" rims 225/50 tyres. Has the disc brake conversion. Not sure of the exact piston size but estimate 30mm. Single piston. 9.5" rotors. Pads app 1.25" tall. Pedal leverage ratio 4.75:1
No idea what master cylinder has been fitted. Looks like it's from a car. Can only read the make Brembo. Body diam is 30mm.
There is some weeping where the reservoir tube joins the body but it's not much. No idea how old the fluid is. Brakes feel mushy.
Thought I'd try & find out what ought to be on there before doing anything or spending money.
I went down the 'would the Vmax OEM one be right' rabbit hole. It's 13mm. Using bike calculations/chart I was getting I need 12mm.
I looked here to check only to find 3/4" (19-20mm) or more being talked about so now I'm lost.
All advice gratefully received.
The trike:
