CSC Bottom Trunk
Truckdogg4
10+ Posts
Sep 17, 2022
7
1
Decatur
Has anyone had any problems with water getting into the bottom trunk on a CSC Encore? If so, what did you have to do to fix it.
I have a Harley - so, my conversion is not an Encore. Given that you have a 2021 and CSC has a 5-year warranty, you may want to contact them and get it repaired.
Talk to Dwight when he was in litchfield, il. He said to look in the top corners make sure the rubber goes in the corners all the way. Plus tighten the Latch a Little .
Which. I haven't washed the trike to see if it fixed the problem yet.
Silicone does wonders
The joint where the rubber meets is the spot my lower trunk was getting wet. I just silicone the joint together and put some inside the opening. took off the excess and closed the door so it be formed shut whendried. It had a puddle of water on the bottom letting it leak inside. the top would've keep the water running off. No I'll see if this works in the real world, garden hose it did.
Drew73
Drew73
