air horns
May 9, 2011
16
bridgton me
Have an 08 goldwing trike CSC. Looking to add an air horn. Need to know what people think is best and also where to mount it. Any help would be appreciated. Thank you.
Skibridg
I 2nd for Rivco. Mine have lasted 25,000 miles problem free on my Tri-glide. Worked in ALL weather conditions. Note to make sure you order ones with front cover. It blocks crap getting in. I ran the air hose to compressor under rear seat also (the only room I could find).
VTX1800F Roadsmith
Installed a chrome WOLO (Setbel) above the stock horn on the downtube, with a ss hose clamp and piece of 1/2 alulminum strap from ACE hardware. Hose clamp is so folks have to work harder to steal the horn; went through two before I installed the hose clamp, the WOLO has a slip on mount that makes it a one hand removal (love those group bike runs!)
Installed it with a relay to power it from the battery when the horn button is used so have both horns without overloading the OEM horn switch.
The horn is as loud if not more so than RIVCO and Bobs Horn, IMO.
I have a airhorn I bought at PROPAD inc. I needed to move it for my parade fan so I took the cover off and found it was a Stebel air horn inside. It has worked for the last 3 yrs with no issues
I've had Rivco Air Horns on my 89 Wing for 10 years and they still work great. I mounted them under the right saddlebag. Last year at Americsde I put them on my 2000 GL 1500 SE CSC TRike mounted outside of the right side Fairing grille. I wouldn't be without them, they're lifesavers.
Installed a set of RIVCO'S on my Ultra/Champion last week. They mount right where the OEM horn was located and use a relay so the original horn button can be used. Had to mount the little compressor under the seat and the whole installation took about 45 minutes. I love those air horns!!
FYI...I was interested in an engraved cover for the mini beast from Pro Pad. Well I talked with Tracy at Pro Pad yesterday. They no longer offer the engraved version. However they are is coming out with some new medallions in the next few weeks. See photo below of POW one. I am going to hold off on my horn purchase until the new medallions are available.
Denise
wyldesydedavid
wyldesydedavid
