http://www.dayledesigns.com/qt/
This is one but if your going to mount on ice chest rack really you could go with so many different styles That hold more Fuel than these.
Thanks for the link.ThumbUp
I guess you just can't fix stupid, or being cheap.Several years ago I carried an ordinary 1 gal red walmart tank in my saddlebag for "just in case". Never had any problems. One day on a ride with 5 other wings we left the lunch place and were headed to a gas station for refueling but found the station was closed for remodeling. The next nearest station was in Okeechobee, Florida, over 40 miles away. After about 30 miles we pulled over and I shared my gal of gas with the 6 of us. We all got to the gas station ok and most of us took about 6.5 gals. Believe it or not, one or the riders wanted to pass that station and look for cheaper gas down to road.
After reading this thread I decided to chime in with this.
I have a gl1800 /champion trike. Two years ago I decided to install a aux tank. I purchased a tank and quick disconnect from tour tanks and installed it under my rear seat. I connected the main fuel line to the main tank on the bottom with the quick disconnect. I connected the vent to the top of the main tank at the flat spot at the main fuller. I used the two steel straps to hold the tank to the frame of the bike. Yes it is gravity feed but I found that if you use a large enough gas line it will fill quick enough. Also if you set the gas pump on the slow speed fill it will fill at about the same time. One other thing I found is the rear end will come up and touch the tank so I had a metal patch welded to the back metal strap to keep from touching the tank. Works fine. The tank is three gallons so I get around 300+ miles and is a closed system.
the borg
