Battery issue
Feb 13, 2023
2
Vermilion
Question, Has anyone here relocated their battery from the side compartment to the rear lower trunk? I have thought about this, but was wondering if there is an aftermarket battery box small enough for a MC battery. It's a real pain hooking up the battery tender on the Roadsmith trike kit and am wondering if anyone has thought this out. Thanks
Frank
Frank
Frank welcome to Trike-Talk.......:wave4::wave4:.....The easy way is to just put a pig tail on your battery and run it to a spot where you can just plug the tender in this way you don't have to get directly to the battery to plug the tender in any more...
Hi Frank, :welcome: to Trike Talk and your first post
What Bob sad
Easy to install a battery tender pigtail to your battery, once you decide to do this you may want to have your battery load tested first so you do not have any surprises with a bad battery
Clean the battery connections good, make sure the battery is secure( not bouncing around, this will lead to early battery failure)
Frank
Perhaps I missed it - what trike do your have? If a recent Harley, there is probably already a tender plug.
I agree with others - plus, I recommend adding a jumpstart harness (cost about $10) just in case you need it.
I have the pig tail on my Goldwing (Roadsmith) trike........... I use it to also plug in my battery maintainer, every winter season while the trike is sitting in my garage
Ronnie
2/16/23
Jump start harness?
Hey, What is a jump start harness? I’m new to trikes. Can you send me a link to one? In all my life I never heard of such a thing. sure sounds like it would come in handy. I’ve already had some experience with removing those side panels on the Goldwing over the battery and its a pain. Service thru a pig tail and wiring harness sounds good to me.
Just Google pig tail for a motorcycle battery…👍..
You can get this from Amazon. By using this, you can connect the wires to your battery. If the battery fails, you can connect this to a jumpstart kit and jump the bike.
In addition, you can also use the connector to make it fit your battery tender - so, this does the job of two things. Make sure you use the extra plug to connect to the tender
[h=1]LIXINTIAN 10AWG Connector Cable, 1.3ft EC5 Female Plug to O Ring Terminal Cable, 5.9in EC5 Male to SAE Power Automotive Adapter Cable, with 1 SAE Polarity Reverse Connector[/h]
Pig tail for battery
I know what a pig tail is, just didn’t know what you meant, by attaching it to a jump start harness. Apparently you can jump start with a pigtail? I’ll check it out on Amazon.
tw0fast4u
tw0fast4u
