brake lite
Just BOB
40+ Posts
Mar 19, 2019
42
11
Myrtle Beach
i have a 09 stallion the brake lite in dash is staying on i checked the fluid theres no leaks its not low on fluid dont have a clue why is on
If you have a parking brake make sure it is released all the way, there is a switch attached to trip the light. If that is NOT the cause you more than likely have a master cylinder by passing pressure. If this is the problem you should see a lower and spongy pedal . This will require replacing the master cylinder
If you have a parking brake, look to see if there is a switch wired to it. If it does un plug it is the brake light still on? If it is you have ruled out the parking brake
thank you for the info will check it out this week ty again
Roadrunner1
Roadrunner1
