*DK Custom-Dual Cool Oil Cooler-Fits ALL Touring & Trike models inclu. Twin Cooled*
Jun 15, 2013
9,120
8,814
Red Banks, MS
BOOM!
An Oil Cooler That Fits the Waterhead Twin Cam
DUAL-COOL OIL COOLER - Fits All HD Touring & Trike Models
The Patent Pending Dual Cool Bracket catches swirling air and channels it through Two Angle-Cut Holes, forcing two powerful streams of air directly over the front and rear cylinder fins.
Check out the kit as a whole!
Go HERE to see more photos and details!
Why add a Secondary (Auxiliary) Oil Cooler?
Cooler running engines produce more power, last longer, & are more comfortable to ride.
The factory Low-Mount Oil Cooler does provide cooling benefit. But it is not nearly as much in the wind, nor nearly as effective an oil cooler as this oil cooler.
In our tests with the Auxiliary Oil Cooler, oil temperatures were consistently 17-22 degrees cooler, and head temperatures were 15-20 degrees cooler.
FEATURES & SPECS:
  • Air from the Vent in the Lower is forced over the Oil Cooler
  • Patent Pending Dual Cool Bracket Channels Air across the Cylinder Fins
  • Black Powder Coated Finish
  • Fits ALL HD Touring Models with Lowers (including Twin Cooled)
  • Can be used as a Secondary Oil Cooler if you already have a Factory Oil Cooler
  • Utilizes an Included Jagg Deluxe Oil Cooler w/ HyperFlow Technology
  • Optional Braided Hose, Optional Clamps
  • Complete Dual Cool Oil Cooler w/ Everything supplied for an E-Z BOLT-ON INSTALL*
  • Step-by-Step Instruction Included
Go HERE for photos and details!
HomeFree
HomeFree
