****DK Custom Products Has Tri-Glide Lift Kits****
Jun 15, 2013
9,132
8,864
Red Banks, MS
DK Custom Products is happy to offer two different styles of Trike Lifts.
  1. The Standard Trike Lift
  2. The Comfort Lift Kit
Here is how they are the same.
  1. They both replace the stock shock mounting brackets.
  2. They both raise the rear shocks 1.25” and the rear of the bike 1.6”
Here is how they are different.
  1. The comfort lift kit changes the angle of the rear shocks rearward on the swingarm providing for a more comfortable ride by absorbing more of the smaller and larger road imperfections, resulting in less of the bumps being passed on to the rider and passenger.
Click HERE to see these options.
Tri-Glide - Rear Shocks Comfort Lift Kit
Click HERE
Kelsey
Our Standard Lift Kit replaces the stock shock mounts of your Harley trike. It gives an increase of 1.25" at the shocks and 1.6" at the rear. This is the same as the Standard Lift Kit. The taller rear ride height will also help keep your muffler tips from scraping, when entering & exiting driveways,etc.
What is different about the Comfort Lift from the Standard Lift is it also slightly changes the angle of the shocks rearward on the swingarm. The suspension now absorbs more of the smaller and larger road imperfections, resulting in less of the bumps being passed on to the rider and passenger.
An added benefit of a lift kit is by raising the rear end,this will decrease the Trail in the front end geometry a small amount and that will result in slightly quicker steering. It won't be lightened to the point of being twitchy but will offer a noticeable reduction in steering effort.
BEFORE:
AFTER:
If you have any questions about the standard or comfort lift feel free to give me a call at the office. I will be glad to help out in any way I can :)
Kelsey
~Convertible Comfort LiftTM~
Click HERE for more photos and details!
The Convertible Part: On some pre 2017's, and more 2017 HD Trikes, there can be a very close fitment between the swingarm and the exhaust with a full 1.25" Lift.
The Convertible Comfort Lift™ has a second set of mounting holes that allow you to try the full 1.25" lift first, and if there is a fitment issue, simply use the built-in secondary mounting holes. It takes 30 seconds to make the change!
The secondary mounting holes give you almost 1" lift at the shocks & close to 1.2" lift at the mufflers.
Simple & Easy. You end up with the Ideal lift for Your Trike, and all the benefits of a Comfort Lift™.
Go HERE for more photos and details!
Customer Review-
Excellent product and best price! Review by Bubba:
"This is the 2nd kit I've installed on differant trikes. This one by far the best for the price. It was easier to install after learning from mistakes I made installing kit from another Co. on another bike." (Posted on 1/14/2019)
Thanks, Bubba!
Go HERE for more details!
2011Case
2011Case
