fellow triker needs help
i got this off of the gwrra trike site...maybe someone can help him...
thanks, vance in ga...
Author Message
Posted by:
Rex O'Neal
Saturday, June 14, 2008
07:34 pm
I have a 06 California Trike with aux gas tank. I am having trouble with the gas building pressure and is going to the bleed off tank and is leaking on to the ground.Tried to operate trike and will not run properly.It sounds like it is starving for gas.Please, help us with this problem.You can call at 931-625-3034.
ps/ says he stuck in savannah,ga. and needs info asap.
:confused: Try running with cap loose. I'm pretty sure the cap has to bleed off pressure as well as allowing air in to keep from sucking negative pressure in the tank.(?) Jim
