Rogue1
400+ Posts
After searching the web for months, I could find no plug and play marker/running lights for the Tri Glide fenders. I had to engineer a set
myself. I used semi truck marker lights and wired them into the pigtail harness from the Kuryakyn tour pack lid lights. The automotive
industry makes clips that adhere to the inside of the fender. I covered the wires with heavy duty rubber roof seam tape. You better be sure to put it where you want it because once it is down it's NOT coming up. I put the lights at the bottom of the fender to see how they would look. (And not
drill holes in the fender if I didn't have too). I think they look good where they are.
