First ride impressions: an arm wrestling match
My first trike ride- a day ride of 550 miles by C50 Tramp from Van Braun, Arkansas to Houston, Texas -was filled with the expected disconcerting lack of lean, and forgetting the parking brake 3 or 4 times. (quick tip, kids: don’t reach down and release the brake at speed) The absolute necessity of ergonomic modifications was clear immediately- the trike badly needs a back rest, and the foot controls angle and position must be altered.
Most striking, though, was the amount of force required to steer the beast- riding mountain twisties was a full on arm wrestling match. I thought riding a trike was just going to be a bore with the leaning dimension and intimacy removed, but not so- relatively effortless at-speed turns on 2 wheels became a struggle for survival. Strength- not friction -seems to be the limiting factor for how fast a turn can be taken. The challenge level is sufficient to keep my interest and distinguish the conveyance from any other sort of motor vehicle I’ve piloted. That said, I feel as though I’ve had my ass kicked at the gym, muscles worked and complaining. Sure, you don’t have to worry about dropping the cycle- but most everything else is MORE work with the third wheel.
Chris, try this. Just as you get to a turn lean your upper body in the direction of the turn letting your outside arm go straight. Then as you enter the turn sit back up straighter and let your upper body and straight arm push the handlebars in the direction of the turn. You won't wear out your arms and shoulders turning that way.
Also, a rake kit will make it easier to steer.
