fuel pressure gauge
Apr 30, 2015
201
42
pineville, la
Where can I get a small fuel pressure gauge and regulator for my trike? And second where could I mount it. Anyone have a picture of theirs? I hear you need 2 or 3 lbs pressure. Don't have a clue what I have now. I have one on my rat rod that is fairly small and I guess the regulator is also. Trying to remember where I got it from. Suggestions. Thanks
I had this model on my carbed engine.
The same looking ones from empi did not last long. Got these off the wall at a local parts store and they worked for years.
I bet they are in the summit or jegs catalog also.
If you have a low pressure Facet fuel pump or a stock fuel pump you should be good to go. The chrome style regulators are basically a fuel restrictor instead of a regulator. When you turn the knob you either increase or decrease the size of the hole inside, having said that you actually have the maximum pressure your pump will produce at idle and can run out of fuel cruising down the road , I ran one years ago . LOL It was one of those things I hung on my pegboard hooks . If you need a regulator I use the Holley Red ( low pressure ) unit and have had great luck with them. Mike McCarthy
Roadrunner1
Roadrunner1
