Harley Front Tire???
Jan 24, 2011
643
27
The Villages, FL
I have searched "front tire" and all I get is front tire changes for Honda. I found one for a Harley and the person used a MU85B16 rear tire. They did not say if they mounted backwards.
Has anyone put a rear tire on the front of a triglide? Which rotation direction? I notice the MU85 has 11/32" tread depth, the stock front tire has 5/32". What type of tire? What size?
Im running a Dunlop MU85 in reverse direction on my Roadglide trike. Currently I have close to 10k miles on its wearing great. The only thing I would advise you to do is measure the width between your front bumper. I think its slightly smaller then the fender is.
Tom
Ok I understand why you reverse a rear tire when you put it on the front. I'm still a little confused why someone would go buy a rear tire to put on the front. Why not just buy a front tire?
The rear motorcycle tire has a flatter profile to give you more contact area when mounted on the front and the rear tire has more tread depth 11/32" compared to 8/32" for the front. Im looking at 25k miles minimum wear on my current front mounted rear tire. The best mileage I could get out of stock front tire was 15k.
I'm using the Dunlap Rear Bias Ply E3 MT90B-16 74H in reverse rotation on the front of my converted Street Glide. It has a higher weight rating and a deeper tread depth. So I expect I won't have to replace it as often as the front 402. It maybe a little louder running than a 402. The E3 and the AVON Venom tires are the only 2 tires I never found any wild stories about.
Welcome aboard Porky, AH you do realize that we are talking trikes here. The front tire track is well out of the way of the rear tires track.
Correct but the spray of the water will spray out in the path of the rear tires. I have a 2008 and I put the tire on the correct way and spray was not as much as reversed.
I have a Motor Trike kit on my 02' FLHTCUI, tried various brand's of tyre's but the best I have used (and still are) are Shinko Tyre's specificaly made for Trikes. I ride hard n fast
& have 12000 kliks on this one so far, So go & check 'em out
I just made up my mind and installed a MT90B16 rear tire on the front with reversed rotation. On the ride home it seemed to steer better. May have just been because the old front tire was down to the wear bars :) I had gotten 22,000 miles on the original front tire. It was the dealers first time for doing this on a tire.
HomeFree
HomeFree
