Harley Radio, Instruments and Body Control Module Codes
Jack Klarich
18000+ Posts
Oct 11, 2016
17,639
15,846
Jax, Fla USA
B Codes: Radio, Instruments, & Body Control Module
B0563 Battery Voltage High
B1103 LHCM Internal error
B1121(HFSM) Left Turn Output Open
B1121(TSM) Left Turn Output Fault
B1122(HFSM) Right Turn Output Open
B1122(TSM) Right Turn Output Fault
B1123(HFSM) Left Turn Output Short to Ground
B1124(HFSM) Right Turn Output Short to Ground
B1125(HFSM) Left Turn Output Short to Battery
B1126(HFSM) Right Turn Output Short to Battery
B1131(HFSM) Alarm Output Low
B1132(HFSM) Alarm Output High
B1134 Starter Output High
B1135 Accelerometer Failed
B1136(HFSM) Accelerometer Tip Test Error
B1141(HFSM) Ignition SwitchLow/Open
B1141(TSM) Ignition SwitchLow/Open
B1142 Smart Security System Internal Fault
B1143(HFSM) Security Antenna Short to Ground
B1144(HFSM) Security Antenna Short to Battery
B1145(HFSM) Security Antenna Open
B1151 Bank Angle Sensor(BAS) Short to Ground
B1152 Bank Angle Sensor(BAS) Short to Battery
B1153 Bank Angle Sensor(BAS) High
B1153 RHCM internal error
B1154 Clutch Switch Input Short to Ground
B1155 Neutral Switch Input Short to Battery
B1200 IM internal fault
B1210 Fuel level sender shorted low/open
B1211 Fuel level sender shorted high
B1212 Fuel signal low
B1213 Fuel signal high
B1300 Radio voltage high
B1301 Radio voltage low
B1302 Face plate home button stuck
B1303 Face plate favorite button stuck
B1304 Face plate navigation button stuck
B1305 Face plate power/mute button stuck
B1306 Rear hand controls shorted high
B1307 Rear hand controls shorted low
B1308 Rear volume up button stuck
B1309 Rear volume down button stuck
B1310 Rear mode button stuck
B1311 Rear PTT button stuck
B1312 Rear tune up button stuck
B1313 Rear tune down button stuck
B1314 LHCM VR button stuck
B1315 LHCM up button stuck
B1316 LHCM left button stuck
B1317 LHCM center button stuck
B1318 LHCM right button stuck
B1319 LHCM down button stuck
B1320 RHCM Info button stuck
B1321 RHCM up button stuck
B1322 RHCM left button stuck
B1323 RHCM center button stuck
B1324 RHCM right button stuck
B1325 RHCM down button stuck
B1326 RHCM CB squelch up button stuck
B1327 RHCM CB PTT button stuck
B1328 RHCM CB squelch down button stuck
B1329 Faceplate preset button 1 stuck
B1330 Faceplate preset button 2 stuck
B1331 Faceplate preset button 3 stuck
B1332 Faceplate preset button 4 stuck
B1333 Faceplate preset button 5 stuck
B1334 Faceplate preset button 6 stuck
B1335 Faceplate preset button 7 stuck
B1336 Faceplate preset button 8 stuck
B1337 Front left speaker shorted together
B1338 Front left speaker open
B1339 Front left speaker shorted low
B1340 Front left speaker shorted high
B1341 Rear left speaker shorted together
B1342 Rear left speaker open
B1343 Rear left speaker shorted low
B1344 Rear left speaker shorted high
B1345 Front right speaker shorted together
B1346 Front right speaker open
B1347 Front right speaker shorted low
B1348 Font right speaker shorted high
B1349 Rear right speaker shorted together
B1350 Rear right speaker open
B1351 Rear right speaker shorted low
B1352 Rear right speaker shorted high
B1353 Speaker offset DC output
B1354 GPS antenna open
B1355 GPS antenna shorted low
B1356 SDARS antenna open
B1357 SDARS antenna shorted
B1358 Front left headset shorted high
B1359 Front right headset shorted high
B1360 Front left headset shorted low
B1361 Front right headset shorted low
B1362 Rear left headset shorted high
B1363 Rear right headset shorted high
B1364 Rear left headset shorted low
B1365 Rear right headset shorted low
B1366 Internal thermal shutdown error
B1401 Amp voltage low
B1402 Amp voltage high
* Amp 1 Amp 2
B1403 Speaker offset DC output *
B1404 Internal thermal shutdown error *
B1405 EQ correlation error
B1406 Invalid or missing EQ
B1410 Channel 1 speaker open *
B1411 Channel 1 speaker shorted low *
B1412 Channel 1 speaker shorted high *
B1413 Channel 1 Speaker shorted together *
B1420 Channel 2 speaker open *
B1421 Channel 2 speaker shorted low *
B1422 Channel 2 speaker shorted high *
B1423 Channel 2 speaker shorted together *
B1430 Channel 3 speaker open *
B1431 Channel 3 speaker shorted low *
B1432 Channel 3 speaker shorted high *
B1433 Channel 3 speaker shorted together *
B1440 Channel 4 speaker open *
B1441 Channel 4 speaker shorted low *
B1442 Channel 4 speaker shorted high *
B1443 Channel 4 speaker shorted together *
B2102 System power output shorted high
B2103 System power output shorted low
B2104 System power output overloaded
B2106 L4 output open
B2107 L4 output shorted high
B2108 L4 output shorted low
B2109 L4 output overloaded
B2112 ACC output shorted high
B2113 ACC output shorted low
B2114 ACC output overloaded
B2116 Fuel pump output open
B2117 Fuel pump output shorted high
B2118 Fuel pump output shorted low
B2119 Fuel pump output overloaded
B2121 Starter output open
B2122 Starter output shorted high
B2123 Starter output shorted low
B2124 Starter output overloaded
B2127 E4 output shorted high
B2128 E4 output shorted low
B2129 E4 output overloaded
B2131 High beam output open
B2132 High beam output shorted high
B2133 High beam output shorted low
B2134 High beam output overloaded
B2136 Low beam output open
B2137 Low beam output shorted high
B2138 Low beam output shorted low
B2139 Low beam output overloaded
B2141 Left front turn signal output open
B2143 Left front turn signal output shorted low
B2144 Left front turn signal output overloaded
B2146 Right front turn signal output open
B2148 Right front turn signal output shorted low
B2149 Right front turn signal output overloaded
B2151 Left rear turn signal output open
B2153 Left rear turn signal output shorted low
B2154 Left rear turn signal output overloaded
B2156 Right rear turn signal output open
B2158 Right rear turn signal output shorted low
B2159 Right rear turn signal output overloaded
B2161 Brake lamp output open
B2163 Brake lamp output shorted low
B2164 Brake lamp output overloaded
B2168 Running lights output shorted low
B2169 Running lights output overloaded
B2172 H2 output shorted high
B2173 H2 output shorted low
B2176 Security antenna output open
B2177 Security antenna output shorted high
B2178 Security antenna output shorted low
B2183 G2 output shorted low
B2188 G3 output shorted low
B2193 H4 output shorted low
B2198 H3 output shorted low
B2201 IGN switch off w/VSS
B2203 Ignition switch input shorted low
B2206 Run/stop switch input open/shorted high
B2208 Run/stop switch input shorted low
B2210 Run/stop switch inputs both open
B2212 Run/stop switch inputs both closed
B2218 Neutral switch shorted low
B2223 Rear brake switch shorted low (light on)
B2226 BAS input open
B2228 BAS input shorted low
B2231 Fork locked/VSS
B2232 Fork lock shorted high
B2233 Fork lock shorted low
B2234 Fork lock detected with option disabled
B2235 Fork lock configuration invalid
B2250 Clutch switch stuck
B2251 Horn switch stuck
B2253 FTP switch stuck
B2254 Left turn switch stuck
B2255 Trip switch stuck
B2256 LHCM Police siren power stuck
B2257 LHCM Police siren wail power stuck
B2258 LHCM police siren yelp stuck
B2260 Start switch stuck
B2261 Right turn switch stuck
B2262 Front brake switch stuck
B2263 Hazard switch stuck
B2264 RHCM police lights power switch stuck
B2265 RHCM police lights front switch stuck
B2266 RHCM police lights rear switch stuck
B2267 RHCM police ICR switch stuck
B2270 BCM internal error
B2271 BCM voltage low
B2272 BCM/IM voltage high
B2274 Constant battery line error
Roadrunner1
Roadrunner1
