Harley Voyager Steering
I just recently installed a Voyager Kit on my 2010 Harley Ultra Classic. We rode about 1000 miles through the mountains of NC over 4 days. I have two questions; 1. How expensive are the rake kits. 2.What is the recommended air pressure for my rear motorcycle tire(with Passenger), shock pressure and air pressure in the voyager kit tires? Thanks, If you are in NC, I recommend the Iron Horse Motorcycle Lodge and Campground. It is a great place.
When I had mine I kept the rear tire at the factory spec. 30# I believe. The out rigger tires has no effect on the ride or handleing . The thing that makes the biggest difference is the pre load. Place a 2x4 under the rear motorcycle tire. (2" side up actually 1 7/8 ) loosen the rear u bolts puts. Outrigger tires to the ground. And tighten u bolts. Outrigger tires should both be on the ground. Most of the time.
If yours are always one in the air it is wrong. <br />
RAKE KIT WILL NOT HELP WITH A VOYAGER .. It will be dangerous.
I sell rake kits for $695..You need to run max air pressure in the bike tires and 20 LBS in the outrigger tires.
Sylvester
Sylvester
