Help required from Goldwing 1800 CSC owners
The Wolf
TOI - Scotland
Mar 15, 2008
1,178
82
Livingston Scotland
Hello Guys...Are you able to assist my trikey pal with this dilema?
Here goes:
"I own a 2004,1800cc Cobra CSC trike conversion. Can anyone help with any information regarding raising the body for more clearance on the rear wheels. Further to this has anyone with the same conversion, when rocking the trike side to side, I get a knocking from the rear"
Can anyone help? Thank you in anticipation,
Jake
PS It will make an old guy very happy if he is able to have this question answered.:yes::yes::yes:
The bodies are shimmed at mounting time. The amount of lift is set pretty much by what is required to get the side covers etc... to line up correctly and allow the side panels to properly attach to the grommets. I do not believe you can raise the body higher without causing yourself more problems.
As to the "click" sound when rocking the trike side to side.
IF you can, check the torsion bar and its connecting links, See if you can find your problem there. I have seen the torsion bar link ends become loose and it is a bit of a job to repair.
How Old is your kit?
Regards,
Chuck
Wolf, back in the day I raised the body on my jeep by drilling a hole in hockey pucks. I added 1 to each body mount using longer bolts, it raised it about 1 inch, hardly noticeable but got me the clearance I need.
I wouldn't try that with a CSC or any other Kit,,,, unless you want to completely redesign the tour pack (trunk) mounting and the side covers re made to conform with the New Shape..........
Some of these kits have very little tire clearance The CSC is one of them.
Roadrunner1
Roadrunner1
