This is my second message.. I have a 2005 Honda GL1800 Lehman Monarch II Trike. I have a rubbing noise when I sometimes make a right turn and also when I am going slowly into the garage. When I hear this rubbing sound, if I hit either the front brake or the rear brake, it stops. I had it at Ace Motor Works in Pitman NJ and they thought they corrected the problem by shaving the brake pad a bit. Unfortunately the rubbing noise is back again. I don't know what to do or where to take it to correct the problem. I just spoke to Pat at Ace Motorworks and he said to bring it back and they will check it out. They are a good company to deal with. If anyone can fix the problem, they are the ones.
When I enter my driveway, I have a slight incline and the mufflers rub slightly on the bottom. Could this have any effect on this noise problem ?
