Can anyone give me some info. I have an 87 goldwing, 1200, aspencade. Just had a new volt regulator and stator put on it. But I can ride about 40 - 50 miles, just long enough for the motor to get hot, and turn it off. If I try to crank it back up right away or before it cools down it acts like the battery is weak and has a slow turn over. But if I put a jump box to it, it will fire right up without any hesitation. I talked to the mech. that worked on it and he said that the battery read 13 volts ( which it should be between 12 - 14). I looked on internet and it said crank engine, remove positive wire from battery to check if stator is working. If it stays running then stator is working.( It stayed running) Also had battery checked yesterday and it showed "Good - Recharged Batt") Battery is 1 month old. Can this possibly be a starter problem?
