how to keep Trigg trike kit from excessive tilting ?
Hello and :welcome: to Trike Talk, glad to have U with us. :clapping:
I had a Voyager kit on a GL1500 Goldwing and there were 'Preload Adjustments that had to be set, air shock pressure and tire pressure any leaning had to be adjusted with washers on the belly bracket. I have no idea if it uses the same design, :xzqxz:
can anyone help me by how to keep my motorcycle from tilting alot my 1999 yamaha royal star venture tends to tilt more to the right and as i back up tire tends to rub...... Edward
Its a easy job just ajust the 2 turn buckles so the trike is setting level then ajust down pressure on rear wheel so as it not let the bikes rear wheel spin without moving the trike. You just have too play a little bit until you find the sweet spot.
Sylvester
Sylvester
