In the experimental stage but getting close to what i want?
SOP.....Most posts come out double spaced......I kinda like it, What with my Dyslexia it makes most post easer for me to read, And in turn to understand...:Shrug:
Patent it and give me a cut?
Maybe I can buy some new exhaust pipes before I kick the bucket?
Kevin, im not exaggerating when I talked of wind drag, I even noticed my tach running a might slower than normal at 60 mph.
Your a might wrong about added wind resistance, The Plexiglas is concave rather than flat and the way its tilted creates a slip stream rather than a barricade.
Im going to tip the edge out into the wind a little more to avoid the three bugs I washed off yesterday.
You will notice more bug spatter on the shield closest to barrow ditch.
If a big bug comes in from the side there isn't much you can do about that one except hope it hits the passengers legs? LOL
( I didn't say that, I plead the fifth )
Sorry, what I meant to say is that the little bit of drag there is from your invention is much less than the drag that is no longer there because of it. Net result is less drag. Very cool.
I think it looks really good as it is.
Patents can be expensive....there are design patents and utility patents...google will explain the difference. Cost can range from $1000 to $5000, and that is doing them on a budget...it is easy for them to go far higher! And that is just to get them...then there are maintenance costs, and, unfortunately, the possibility of having to protect your patent, which can be the most expensive part of the process, making the initial costs look like pocket change.
This part is not one I see us pursuing, not because it is not good...just does not fit our current set-up. However, if you want some contacts for patents, shoot me an email at Kevin@DKCustomProducts.com and I'll get you some info.
Kevin im not concerned about patents I just wanted to share it and what I made it out of.
I don't have enough time left to start a business and see it to fruition.
well I tried switching sides and turning the wings upside down and it just didn't work as well as I imagined, so I turned them back around and did some adjustment, Gonna run em that way.
Drew73
Drew73
