***Introductory Special on Velocity Stack Intakes from DK Custom***
Jun 15, 2013
9,120
8,814
Red Banks, MS
Introducing the V-STACK
An Uncompromising
Four Finishes
Two Lengths
Raw Stainless~Black Powder
Raw Aluminum or
Mirror Finish Aluminum
1.5" or 3"
10% Introduction Savings
March 6-17, 2015
Use Coupon Code: Save10
In Checkout
Or Call In Your Order at 662.252.8828​
<tbody>
</tbody>
See All the Photos & Details by Clicking V-STACK
Re: ***Introductory Special on Velocity Stack Intakes from DK Custom***
You can upgrade to the Outlaw V-Stack Air Intake Complete System without doing any dyno work or adding tuners IF you leave the stock exhaust in place.
Kelsey
This intake is as free flowing as you can get and you have the option of the 1.5'' V-Stack or the 3'' V-Stack!
Kelsey
[FONT=verdana, geneva, lucida, lucida grande, arial, helvetica, sans-serif][/FONT][FONT=verdana, geneva, lucida, lucida grande, arial, helvetica, sans-serif]SAVE WHILE YOU CAN :)
[/FONT]
Kelsey
[/FONT]
I like! My Dyna would look good wearing one of these.
Do you need to put a rain coat on it when it rains?
Would it be wise to re auto tune after installing?
Heavy rain would be good to have a rain sock.
If you already have a free flowing A/C, no new tune is needed.
If your replacing the stock A/C and still have the stock exhaust, no new tune is needed.
With your Power Vision, would not hurt to do an auto-tune, but I doubt you will see much change in the tune from the auto-tune if you're going from another free flowing intake to this one.
There is an exception...if you currently have a free flowing A/C, but it is still dumping the crankcase pressure into the air cleaner...when you switch to the V-Stack, you are now putting only clean, cooler, more oxygen rich air into the combustion chambers. While you do not Need (no damage will occur if you don't) to do a new tune, it would certainly be beneficial...you now have more oxygen, and that means you can have a stronger combustion stroke!
Does it come with a rain sock? Or do you know of one that fits? We don't get much rain here in the "high desert", but we usually do when I'm on a trip.
I have a sock that fits the HD stage one air cleaner, but I doubt that will fit.
They currently do not come with one. Devin and Kevin(DK) are in the process in looking for a Rain Sock now that will go with the V-Stack. You can check back with us or even if you would like you can call the office and we can contact you when we do find one :)
Kelsey
Kelsey
With this ac, where does the crank case dump to?
After seeing them on a bike I can say they are real well made and look great!
There are several choice in external breathers- you can see them at the following links
http://www.dkcustomproducts.com/Pre...Cam-Touring-Softail-Dyna-DK-PR-DIS-BRT-TC.htm
or the Black, Polished Aluminum, or Brass Breather Bolts at this link-
http://www.dkcustomproducts.com/All-Twin-Cam-Engines_c76.htm
Sylvester
Sylvester
