Lehman rear tail lights
Jan 29, 2022
27
17
Waskom Tx
The right rear brake light does not come on. I have changed bulb, no brake light this is a 97 gl1500 with full floor boards. Where does these light get there power from?
Thanks, Ralph
The wire harness was extended via "plug & play" made up wiring included with the kit to relocate the original GL-1500 taillights, if you mean the ones down on the fender. The wiring for them originates in the original harness that are still there under the seat and trunk. A service manual with wire diagram for a GL-1500 will help.
1. Identify the wires to the tail/brake lights on the original wiring harness. Plug extensionharnesses into the originals.2. Remove the inner panels at the back of each wheel well (5 screws)3. Feed the extension harnesses into the light pockets through the drilled hole in thebottom of the pocket. You will have to remove the plug off the harness first.4. Install the taillights from inside the fender. Put the flat end into the recess at the side ofthe inner trunk and rock the curved end into the cavity. Position the light in the bodyopening.5. Reinstall the plug on the harness and connect the electrical plugs. Neatly coil theexcess harness under the tour pack and fasten away from any heat sources or movingparts that could cause damage to the harness. Fasten harnesses to the tabs attachedto the side of the trunk to keep them from getting damaged.
Tail lights
Thank you for the reply. I have the service manuals for the wing. Needed a starting point! Again thank you
Be Safe, Ralph
Drew73
Drew73
