Locked Out of Lower Trunk
Jun 21, 2009
305
7
Whortonsville, NC
Friday, after we finished bottom painting the GF's boat, I tossed some brushes and other stuff in the lower trunk and came on home. Got home and the lower trunk wouldn't open. <img src="images/smilies/smiley confused.gif" border="0" alt="" title="confused" class="inlineimg" /> Naturally I took the seat off so I could grab the "emergency cord" on the Champion conversion. <br />
<br />
Lo and behold - the cord had dropped down under the frame and I couldn't get to it by hand. <img src="images/smilies/poof.gif" border="0" alt="" title="poof" class="inlineimg" /> So I "sacrificed" one on the few remaining wire coat hangers in the house to make me a retrieval hook. <br />
<br />
Learned a couple things from this exercise:<br />
a. It doesn't do you any good to have a tool kit with the allen wrench in the lower trunk. Got to have the wrench to get the seat off in an emergency. Now have a spare wrench in the top trunk.<br />
b. To prevent the "emergency cord" from falling in to the frame again I hooked the "finger loop" over one of the studs that's used to secure the seat to the frame.<br />
<br />
Just glad I was home for this exercise.
I keep my tools in the upper trunk but its a good idea to be able to get to that Allen that gets the seat off. I had my seat off the other day and noticed that on my Lehman conversion there was a cord tapped to the inside top where the seat attaches which is the truck release. Now I am sure it was like that so that cord doesnt drop down below like yours did.
If theres enough play in the cord up I would put it behind the lower pad of the passenger back rest for easier access. Makes it a lot easier to get to and you dont need a wrench.
Well, you made me look! Emergency cord securely taped to the trunk so I can get at it when the upper trunk lid is open.
On our 1800 Champion I keep a tool roll in the lower trunk in the area above the right wheel, but in the upper trunk I have a bag with hex wrenche to get at the seat off, hexes to change/remove the passenger floorboards and risers, 2 open end wrenches to take off the passenger arm rests (cant get the seat off with them on, they attach to the grab handles), and a stubby screwdriver with some ball bearing balls to fix windshield vents if the screw comes loose and the detent ball gets lost.
Ummm, haven't checked on the wifes CSC, but in the past mine was located under the left side over, no tools needed to pull the cord, just remove the side over..
I am looked out of mine, I am calling the installer but can't get him now. It's a 13 Hannigan. Does anyone know how to get in ?? Joe:xzqxz:
I have it easier with my HD TG. If trunk needs to be opened, I can just drive over a bump in road and it will pop right open. And by bump, a lady bug will do it!
ALWAYS good to keep "external parts removal tools" in a handy, non-locked place on Your Trike or Motorcycle.."been there too and learned the hard way".........:gah:
rramo
